Brief Description: Mounted the stick grips' terminal strip
Mounted the stick grips' terminal strip to the left inboard seat rib. I had been considering the use of angles of aluminum or a custom mad bracket to mount the terminal strip because of the raised reliefs of the ribs lightening holes. I didn't like either of these solutions because they were too heavy or too complicated. I decided to cut some aluminum tubing to make some standoffs that worked out well.
