Brief Description: Connected a 12 and 6 terminal strips together
Connected a 12 and 6 terminal strips together using a small piece of aluminum sheet and four nuts and bolts. This will give me enough terminal positions for the grip wires and the separation of the ground of the front and aft sticks. The aft stick grounds will go to a switch that will interrupt the grounding of the aft stick switches and thus give the capability to inactivate some of the functions of the aft stick.
