Brief Description: Ran 14 ga seat heater wire from Fused terminal
Researched heated seats wiring needs. Ran a 14 ga seat heater wire from the Aft Fused terminal forward to the switches area of the right forward cabin. I will be using a lighted switch for the heated seats power to insure that they don't remain powered while not in use or after shut down. I could have used 16 ga and probably 18 ga.wire but the run is short and the weight of the larger wire is not significant for the more durabley larger gauged wire.
