Brief Description: Ran Remote Starter Switch wire from VP CU
Ran Remote Starter Switch wire from VP CU plug J-5 Pin12 forward to the area of the aft control stick. In this area, I plan to install a terminal strip on the floor rib for the connection of the wires coming from the control stick grips. The wires leaving the terminal strip will run aft to the VP CU.
Now that all of the power wires are run from the VP CU, I made some extra wires of various sizes with Molex crip connectors on each wire. These wires will be used in the future as devices may be added to the VP CU. I will return the crimpng device to Vertical Power. I have been renting it for $10.00 /month. This crimper is essential for good crimping of the connectors used with the VP CU power plugs.
