Brief Description: Made Cables from Contactor to Bus Block
Made Cables from Contactor to Bus Block. The cable from the Main Contactor to the Bus Block is a #6 cable with one end having an 5/16" hole in the lug for the contactor stud and the other end hving a 3/16" hole for the Bus Block stud.
Also made a #6 cable to run from the Bus Block to the Power Stud of the VP CU.
