Brief Description: Fabricated/Installed the Bus Block Mount
Fabricated/Installed the Bus Block Mount to the left of VP CU. This will be used to distribute battery power to the CU, a Fused Terminal Block and any other device that will need battery power independent of the VP CU.. I installed the Bus Block to reduce the number of cable lugs that need to be attached directly to the Main Battery Contactor stud for power distribution.
