Brief Description: Ran Engine Main (Always Hot) Wires up Left Side
Ran Engine Main (Always Hot) Wires from the terminal block, mounted on the intermediate longeron to the left of the batteries, up Left Side to where the Essential Engine Main and Aux switch will be located.
Temporarily installed the step because it partially blocks the bulkhead hole meant for the forward run of the starter fat wire. As it is, the hole is just blocked enogh that I don't like the squeezing of the cable to make it fit the run path. I will alter the path to midline but I will need to protect the cable as it passes through the rib lightening holes and I will need to drill another bulkhead hole for the cable passthrough. I don't think it will be a problem with drilling the bulkheads as needed but I will call Van's to make sure that there isn't an engineering concern for where holes ccan be drilled.
