Brief Description: Tested d-sub pins on the trim 26ga wires
Tested d-sub pins on the trim 26ga wires. These are such small wires to connect to the cable run to the CU that I wanted to see which method I liked best for me. One method is to simply connect d-sub pins to the wires and shrink wrap them together. The connections can be broken in the future as needed but will require careful removal of the shrink wrap to avoid damaging the small wire. Additionally, with all of those shrink wrapped pins with in a short distance of cable run, it will look like a snake that has swallowed a rabbit once they are all shrink wraped together. The other method requires the modification of a d-sub connector into a miniature connector. The second method allows for an easier means of disconnecting the wires in the future if maintenance is required. I like the second method better.
