John (Jack) Clark's Web Site
RV-A8
Started VP Load Planning Sheet
Started VP Load Planning Sheet using numbers for equipment that I expect to be using both in the instrument panel and throughout the aircraft. As with each new phase of construction, this phase is causing a lot of thought and procrastination.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
