John (Jack) Clark's Web Site
RV-A8
Filed and fit the F-858 shoulder anchors
Filed and fit the F-858 shoulder anchors to fit under the flange of the F-808B bulkhead.
Drilled the #40 and #30 holes of the Aft Top Skin that are in common with the Canopy Receptacle, shoulder harness anchors and the upper aft bulkheads.
Drilled the Gossets on the aft sides of the F-807 bulkhead
Deburred all holes and edges. Slightly bent the two side edges of the Aft Top Skin. Dimpled the aft top skin and the flanges of the top aft bulkheads.
Riveted the shoulder harness fairleads to the F-807B bulkhead.
Canopy rail receptacle on top
Aft Top Skin dimpled parts
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
