Brief Description: Mounted Battery Tray Ground Bus Bar
Mounted Battery Tray Ground Bus Bar. Drilled rivet and bolt holes, removed paint from area under the brass bar and surface converted the newly stripped and polishied area. Finally, the tray was spot repainted.
Drilled 5/16" holes for the bolts to hold the battery contactors.
