Brief Description: Installed Pitch Servo Control link
Installed Pitch Servo Control link and wired the Pitch Servo atachment bolts
Per TruTrak, the drawing for the linkage installation is not for installation on a pre-punched RV-8. For the pre-punched RV-8, the the linkage is set to mid range on the threads for the rod bearing ends.
Safety wire was installed on the bolts not having a stop nut.
Will order and replace the center bellcrank bolt to insure at least one thread protrusion from the nut.
