Brief Description: Installed the Pitch Control Servo
Installed the Pitch Control Servo. The one thing I mentioned to TruTrack is that they should include a hardware callout sheet to clarify what hardware goes where during the installation. It can be figured out but takes time and increases fellings of doubt. With all holes filled, I had a few extra bolts. Also, I discovered on vansaircraft.com where I needed to install star washers.
I could not install the control link because the length of the control link with the rod bearing ends installed was far longer then what was called for in the installation drawings. I need to call TruTrak again.
