John (Jack) Clark's Web Site
RV-A8
Added Gear oil to the PSRU
Added synthetic 75W-90 Gear oil to the PSRU x 16 oz.
Cranked the engine using battey jumper cables and a remoter starter trigger I got from NAPA. One clip on the relay's hot terminal and the negative clip on the small spade terminal on the relay.
Trigger connected to relay
Trigger clips on relay
Power and ground from battery
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
