Brief Description: Fabricated a Parking Brake bracket
Fabricated a bracket to replace the F-866D brake line bracket that was attached to the F-866A bulkhead. This bracket was removed so the Matco Parking Brake can be installed in its place. Using 0.063" aluminum, I fabricated a bracket for the brake. I match drilled the rivet holes from the old bracket and match drilled the parking brake's AN4 bolt holes. After repeated measurements, I drilled holes for the straight AN fittings that will connect to the brake hoses from the brake pedals. These holes were oversized to insure clearance of the fitting when attached to the bracket.
