Built a rear rotisserie with James Hoffman. It works well and gives the fuselage mobility. The pipe I used is a bit too long and I may shorten it in the future. I drilled some index holes in the pipes so I can lock the fuselage at 90 degree angles. I plan to add 45 degree angle holes. Materials were: 1" pipe threaded on both ends, and end cap for the inner pipe, 1.25" outer pipe, and a 1" opening threaded sidewalk flange that is screwed to the poplar board fitted earlier.
