Brief Description: Closed Right Bottom Outbd wing skin panel
Closed Right Bottom Outbd wing skin panel and half of the Right Bottom Outbd panel. Stopped to wire heated pitot tube. Unstalling Molex connector on the 24 ga wires. If, in the future, I had to remove the wires from the screw terminals on the controller, I'd never be able to hold the wires in their slots while I tried to screw the terminals shut. It is a two hand job and only one hand will fit into the area. With the connector, this will not be an issue.
