John (Jack) Clark's Web Site
Date:  7-19-2008
Number of Hours:  0.75
Brief Description:  Set Elevator Rod Bearing depth to 7/8"
Set Elevator Rod Bearing depth to 7/8". Awaiting ordered temporary hinge pins from Avery's. Since the control surfaces will be on and off several times, I'm hoping that the Temp. pins will make the task easier since the work space is so confined and would be difficult putting the fastening hardware in place.
Hinge bearing w/o jam nut
Adjusting bearing length
