Brief Description: Drilled the four bolt holes in the HS front spar
Drilled the four bolt holes in the HS front spar and through the F-884 Attachment Plate.
Broke out the rod bearings for the elevator and took the elevators out of storage. Inserted the bears part way. They have a lot of resistance. I'll have to find a way to finish tightening them without dmaging the bearings.
