Brief Description: Installed VS Front Spar centering lines
After drilling the rear spar of the Vertical Stabilizer, I drilled a #21 centering hole in a metal yard stick and a #40 hole equally distant from each end of the ruler. The ruler was clecoed to the middle rudder mounting hinge and a fishing line was run from the ends to the center hole of the F-802-VPP Forward Fuselage Brace. This is a distance from the tail and on the centerline of the fuselage. It will be used to center the Vertical Stabilizer front spar. From a given point, there will be an equal distance from the VS to each stretched line.
