Brief Description: Finished re-assembly of the rear spar to HS
Finished re-assembly of the rear spar to HS.
Checked the balance fore and aft and laterally of the fuselage.
Mounted the HS to the fuselage with the F-810E Spacers under the forward spar and a 3/16" drill bit spacer under the rear spar. Checked the lateral balance of the HS on the fuselage.
