Brief Description: Assembled, drilled, primed elevator bellcrank
Assembled and match drilled elevator bellcrank and the rod bearing ends of the elevator push-pull tube. Primed the parts of the elevator bellcrank and the inside and outside of the push-pull tube after riveting the rod bearing ends into place.
