Brief Description: Torqued the installed Main Gear Weldment bolts
Torqued the installed Main Gear Weldment bolts after installing the washers and nuts. I thought that this was going to be a difficult job since the only access for all of the bolts is through the lateral openings of the Center Section Spar. But this was actually quite an easy task thanks to the aid of washer holders that I got from Avery's and some Duct tape on the back side of a closed 3/8" wrench. I Duct taped the tools to some scrap aluminum bar and was able to easily reach each bolt.
