Brief Description: Squared the Horizontal Stabilizer
Squared the Horizontal Stabilizer by leveling the fuselage left to right at the center section carry through and then in pitch at the Aft deck.
Squared the Stabilizer with measurements from the end of the aft edge of the Cockpit Rails to the Aft corners of the Stabilizer. The measurement came out to be exactly 101 inches.
The F-810E Spacers are under the front corners of the forward spar and a 3/16" drill bit is being used as a spacer under the aft spar.
