Brief Description: Fabricated the F-864E Cable anchor
Fabricated the F-864E Cable anchor, match drilled #30 the holes common to the F-8100A Throttle Quadrant and the F-864E. Tapped these holes in the F-864E to 8-32. Enlarged the matching holes in the F-8100A to #19. Drilled 1/2" holes and deburred/shaped the F-864E.
Deburred the F-8100A and the F-8100B Throttle Quadrant Cover. Surface converted the back sides of the pieces and the Cable Anchor. Sealed these surfaces.
