Brief Description: Assembled the F-8113 Mid-Cabin Assembly
Assembled the F-8113 Mid-Cabin Assembly by match drilling the F-8113A L&R Console Side Ribs to the F-8113B L&R Mid-Cabin Covers then deburring and surface converting the bottom surfaces of the pieces. The #40 holes were dimpled then riveted together.
The above assemblies were clecoed in the fuselage and the outboard four hole were drilled to #19 holes and the holes were deburred.
I skipped steps involving the fuel selector valve because I'll be installing a Andair valve that I don't have at this time.
