John (Jack) Clark's Web Site
RV-A8
Re-bent the left upper longeron
Re-bent the left upper longeron. Fit the longeron to the fuselage. Attached the cockpit rails and checked the longeron placement relative to the small slot in the cockpit rail.
Longerons correctly fitted
Cockpit rails in place
Lt longeron with correct bends
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
