Brief Description: Fit the upper longerons, re-bent the Rt longeron
Fit the upper longerons. Discovered that the longerons were bent in the wrong directions. My mistake was that when I looked at the transected view on the longeron on the drawings, I held the longeron oriented the same as the drawing showed in the B-B and C-C views. I should have realized that the transverse view represented should have been rotated while keeping in mind that I was looking at the top view drawing of the longeron. If there is a question as to the correct bend orientation of the longeron, review the drawings of the longeron position in the forward upper engine mount weldment, this will show the correct final shape of the longeron.
