Brief Description: Clecoed the Fwd/Center/Mid Fuselage together
Clecoed the Fwd/Center/Mid Fuselage together.
Clecoed the Seat Ramp Sub-assembly to the fwd inbd seat ribs.
Drilled and attached nutplates to the Main Landing Gear Weldments (WD-821 L&R).
Trimmed the F-826 Seat Rib Sub-assembly skins from the Landing Gear holes in the Fwd Floor Assembly
Bolted the WD-821 L&R Main Landing Gear Welments to the Center Section with three bolts, two on the top and one on the bottom, to hold the weldments flat against the Center Section.
