Brief Description: Bent the pitot system tube into the mast
Bent the pitot system tube into the mast. This was after finally deciding that I will bend the tubeinto the mast instead of installing a nylon tube and service loop. This would have required more pieces and could result in a greater chance of leaks in the system. For now, bending the tubing seems to be working out quite well. When the heated pitot tube is installed, the installed aluminum tubing will bend slightly into a service loop without concern. Had to order some fittings. I'll have to wait for their arrival before continuing.
