Brief Description: Pitot tubing and conduit tubing installed
Pitot tubing and conduit tubing installed. The pitot aluminum tubing is terminated in the bay outboard of theaileron bellcrank inspection access. A plastic tube will be attached to run to the Gretz heated pitot tube located two bays outboard of the inspection access. The plastic tubing is necessary to allow installation and future removals for inspection and maintenance. I will be able to reach the aluminum/plastic tubing interface through the access should I need access to the proximal end of the plastic tube in the future. Prior to closure, I need to insure that the aluminum pitot tubing is well away from contact or interference with the aileron bellcrank.
