John (Jack) Clark's Web Site
RV-A8
This finished the Left flap
Removed Lt flap bracket and riveted end rib then re-attached the bracket. Bling riveted the flap ribs to the spar. Attached the hinge to the bottom of the flap and riveted the bottom and the top line of rivets.
This finished the Left flap.
Flap actuator bracket
Top surface
Flap spar/hinge view
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
