Brief Description: Riveted the Lt tank baffle and end attachment brac
Riveted the Lt tank baffle and end attachment brackets thus completing the riveting of the left tank. Twenty two of the first inboard bottom rivets were replaced with Oops rivets because I got carried away with the deburring of the skins and deburred these holes before I realized that I was actually enlarging the countersunk holes. All of the baffle rivets were wet riveted.
Ordered fitting caps for the fuel supply and return fittings that will be used for the pressure testing of the tank and during storage to prevent contaminants from entering the tank. Also ordered more sealant for the other tank baffle. I'll be working on the wing skeleton untill I can test the tank.
