Brief Description: Installed New Valve Spacers and Measured Gaps
Installed New Valve Spacers and Measured Gaps. The good news is that some of the gaps are within limits. The bad news is that the valves that we quessed at the replacement spacer sizes, because there was no gap at all, were still too tight. Another delay because the new spacers will need to be ordered. The other problem is that each time we change the spacers, we need to disassemble the front and aft plates to remove the camshafts. This alot of work to change spacers.
