Brief Description: Installed flop tube left tank then removed it for
Installed flop tube left tank then removed it for tank assembly.
Assembled the left tank skin and ribs with 100% clecoing in preparation for prosealing these parts of the left tank.
Attached the trap door on the second rib. Because the door didn't seat well because of the rivet shop heads hitting the rib, I put a spacer piece of aluminum behind the piano hinge to help the door to hang straight down.
