Brief Description: Fabricated the T-405 Tank Attachment Angles
Fabricated the T-405 Tank Attachment Angles after I finally figured out that the R1 in the drawing meant a radius of 1". Made a paper template for the inside edge that follows the shape of the rib tip by using the backing plates for the shape.
I fabricated an Angle for each tank, mirror images of each other. Rough cuts were made on the band saw and finer material removal was with the sander. Next session I'll fine sand/buff/round the edges.
