Brief Description: Changed the Prop Controller Connector Wiriing
Changed the Prop Controller Connector Wiriing. This was done because the way the plug was wired was very much different from the way the instructions I received with the Propeller showed the connector configuration. In the end, It didn't make any difference. The propeller blades still did not change pitch when commanded and the same lights were showing. I'll have to wait for the loaner controller for further testing.
I decided to test the wiring again to see if there was any problems. This time, I used the Bench power source to apply power to the prop motor, from the controller connector, through the wiring harness that I had pieced together. The power flowed through the harness, to the brushes, through the sliprings and then to the motor. When power was applied, the blades changed pitch as they should. This test result meant that the wiring and the motor were good. That leaves the controller.
