Brief Description: Checked the Rigging of the Ailerons
Checked the Rigging of the Ailerons. Secured the control stick in the neutral position using dowel rods taped to the stick and their ends butted up agains the fuselage sides. Using the aileron bellcrank neutral jig, checked and adjusted the control stick control tubes lengths for insertion into the bellcranks. Adjusted the aileron control tubes length to set the ailerons in their neutral positions, aligned with the flaps. Wings' controls are now rigged, jam nuts tightened and witness marks applied.
