Brief Description: Tacked the Cowling Nose Ring to the Cowling
Tacked the Cowling Nose Ring to the Cowling using one ply of glass in areas well approximated with the cowling. First the ring was trimmed to fit as well as possible in as many areas as possible. The final fit was fairly good in many areas but some will need a bit of attention as the ring is attached to the cowling. After the tacks are cured, I'll go back and finish the glass layup to secure the ring to the cowling. It looks like this is going to work out very well.
