Brief Description: Glued Layers of Pink Styrofoam Sheet Together
Glued Layers of Pink Styrofoam Sheet Together to form a 12" cubed block of foam. I have to form a better oil cooler inlet in the cowling than what Jan gave me to work with. I decided to try making a solid foam plug that I could lay glass upon to form the opening. The foam block will be cut and sanded to shape the inlet opening and the transition of the cowling to the the Oil Cooler.
