John (Jack) Clark's Web Site
RV-A8
Trimmed the Aft Top Edge of the Skirt
Trimmed the Aft Top Edge of the Skirt after making a paper template using some posterboard to obtain symmetry.
Drilled and trimmed the lower empennage fairings that I had fabricated earlier. Will need to blend the bottom and the top empennage fairings.
Template for Trim Lines
Trim Lines for the Upper Skirt
Bottom Right Empennage Fairing
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
