Brief Description: Cut and Shaped Aft Skirt to Clear Empennage Fairin
Cut and Shaped Aft Skirt to Clear Empennage Fairing so the canopy can be easily removed in the future. The canopy skirt now is clear of the empennage fairing when the canopy slide block reaches the end of the canopy rail.
Applied glass to the aft skirt exterior joint after shaping and shaping the exterior surface. Sanded a kerf edge along the top of the aft skirt then cleaned the surface with acetone. Applied several layers of glass to the top of the aft skirt edge to built up the edge for future cutting and shaping as I attempt to achieve symmetry.
