Brief Description: Rewired the Grounds of the Copilot Stick Grip
Rewired the Grounds of the Copilot Stick Grip. I re-grouped the grounds of the grip so that as many as possible are connected to the Ground disconnect switch located on the right switch console in the cockpit. As it is, the trim and the flaps switches run directly to the Vertical Power Control Unit and are controlled by the Unit. I can't disconnect these functions with the disconnect switch without installing more switches or a relay. I may do this in the future but not at this time. It is not that important tight now.
