Brief Description: Installed Hat Shelf Access Door Latch
Installed Hat Shelf Access Door Latch. Made a template of the latch opening then opened the hole using a hand nibbler. This did a good job getting the opening to a nearly finished opening needing minor refinements using a file. I had to remove material from the bar onto which the latch grabs. I used a burr/grinding bit on a drill and finished this with some filing.
