John (Jack) Clark's Web Site
Date:  7-30-2012
Number of Hours:  6.00
Brief Description:  Applied Microballoon Slurry to Empennage Fairings
Applied Microballoon Slurry to Empennage Fairings. After about 6 hours, I shaved the microballoon slurry with a 4" Stanley hand planner often referred to as a "Cheese Grater". This worked well to remove some of the excess slurry, resulting in a fairly smoothed surface to start the sanding process. The nice part is that a good portion of the slurry was removed as nice little curls of material instead of the dust generated by sanding. Sanded the fairings with 80 grit sand paper.
Applied a layer of Awl Fair to the rudder bottom fairing. Trying this to see how well it sands and fills pin holes.
Awl Fair on Rudder Bot. Fairing
Microballoon Slurry Applied
Sanded Microballoon Slurry
