Brief Description: Return to Troubleshoot Missing ELT GPS Signal
Return to Troubleshoot Missing ELT GPS Signal. Starting fresh, I decided to start from the source and trace every wire and connection to the ELT. Starting at the Integrated Avionics Hub, I found the problem right away. The Configuator Plug was not in the Correct place. It was on the connection below. Moving the plug solved the problem and the test LED Illuminated as it should!
