Brief Description: Checked ELT GPS Signal without success
Checked ELT GPS Signal without success. There is a test pigtail that was installed on the ELT connector during installation that is connected to a small resistored LED light to test the reception of a GPS signal from the GNS 430W. If receiving a signal, the light flashes about once a second. This did not happen. I checked all of the wiring for correct connections and continuity. All was right but still no light. Frustration setting in, I will return to troubleshooting tomorrow.
