John (Jack) Clark's Web Site
Date:  8-18-2011
Brief Description:  Attached the Left Pilot Map Light Mount
Attached the Left Pilot Map Light Mount to the Center Section Cap after first relieving the center section cover's sides to provide clearance for the rear throttle control rod to the front throttle. I used three black covered brass screws to attach the mount to the cover. This is a good location to use the surface mounts for the lights because once the cover is riveted in place, access to any mounting hardware would be very difficult. This way, the Map light can be unscrewed and extra wire can be pulled from the rear for maintenance.
Soldered wires onto two switches for installation with the remaining two map light installations.
Cover Relief for Throttle Rod
Map Light Mounted
Map Light Mounted
Switches ready for installation
