Brief Description: Connected ELT Power, Ground and Shield
Connected ELT Power, Ground and Shield to the EIS System Terminal. A power wire for the EIS Display and the Firewall Ground wires were connected to the terminal. The last two wires that need to be conneted to the Terminal are the Left and Right Fuel Sender Data Wires to the EIS box. Those will be added when I wire the box connector.
