Brief Description: Wired the Engine Critical Power CommonTerminal
Wired the Engine Critical Power CommonTerminal. There is a common wire to this terminal from the engine control switch that determines whether power for the ECU, Ignition and Injectors, Fuel Pump and the Propeller is coming from the Primary Circuit or the Secondary Circuit. I ran wires from this terminal to the right forward corner of the fuselage (except for the Fuel Pump that was run to the Left Forward Corner). I will be installing the ECU in the front right corner and I will be installing a terminal near the ECU for connecting other essential engine wiring. The front right well of the baggage compartment will become my engine electrical compartment. I plan to add a cover for the baggage well by extension of the horizontal portion of the baggage compartment. This will keep dirt and water out of the area.
